There should be a 3rd belt too, 1 on deck A and 2 for deck BLasonic TRC-920 said:Lasonic TRC 935 & 975 belt sizes
The 2 main belt sizes are:
SBS10.0
SBS6.2
Yes, I did not replace that onebaddboybill said:There should be a 3rd belt too, 1 on deck A and 2 for deck BLasonic TRC-920 said:Lasonic TRC 935 & 975 belt sizes
SBS10.0
SBS6.2
You can use a piece of string to measure.dondigitech said:Anyone have any idea what the correct belt sizes are for the TRC-935? The belts are in pieces and not sure which pieces are part of which belt so its kind of hard make measurements.
