jaetee said:
Any designs our premade crossovers out there that you recommend? What about simply using a coil to kill the mids and highs going to the woofer, rather than a full blown crossover?
Coils would work. Although highly underpowered, when played at moderate sound levels, the RX-7700 has an extremely sweet and mellow sound, no doubt partially attributable to the inductor coils inline with the woofers. I believe it's no mere coincidence that those small 6.5" woofers sound so much bigger. This is the only 1-piecer where I've seen coils installed from the factory. I also believe the same can be achieved with the GF-9696. I have no problem with the sound of the Sharp because I love treble in boomboxes. In fact, any boombox that is lacking in treble would not excite me because I consider treble-light sound quite bland. However, the full range woofers of the Sharp causes it to reproduce far too much of the mids. Add a tweeter and a super tweeter and, well, you can see how the sound might be too brassy or bright for the tastes of many. I don't have any premade crossovers that I can recommend. Firstly, true crossovers are typically fairly large as they are intended to be used with home speakers where space is not a concern and power handling capacity is more important. On the sharp, space is probably at a premium. My recommendation -- install a simple coil between the woofer and the outputs and go from there.
It's certainly worth a try, anyhow.
Jwrok707 said:
I must agree that 9696 looks sweet, but SOUND does matter, it's a tuff trade off. I appreciate the info on the two boxes, I guess price will probably be the determining factor with which one presents itself the best bang for buck.
I doubt you will get the type of deals on the GF-9696 that you can get on the more common JVC. So bang for the buck, JVC. As for sound -- that is all subjective, everyone's ears are different so can't really say how your ears will respond. But I'm pretty sure the most prevalent opinion on sound is going to be the JVC due to better low end response.
