Hitach 8290 belt locations...
docs
2,558
381
United Kingdom
Could someone kindly point out the proper orientation of the belts for this puppy. Opened it up and it was goo central.
Also there is a retaining plate on the bottom which seems to be held on with a single screw, is this the case, just remove the very small screw on the right hand side ?
There seems to be space for 3 belts in there but the documentation about belts indicates 2 main belts and a third for the counter.
Could anyone with one of these shed any light at all please ?
monchito
4,602
11
pythonville florida
well by the looks of it the 2 bottom ones use 1 belt around the 2 wheels and the motor then your top one is the main flat belt capstan wheel and motor :-)
docs
2,558
381
United Kingdom
Could anyone with one of these take a look please ?
No idea what size of belt to order because not sure of the orientation of the belt.
From what I understand from the PRB line reference there are only 2 belts ont he drive.
I'm also struggling to remove the retaining plate from the bottom, anyone ever replaced belts on this thing ? I know it's not hard but I don't wanna fudge it.
monchito
4,602
11
pythonville florida
good doc you saw what i was saying there were 3 belts that run on that motor i just worked on one with basicly the same deck... 1 belt for the white wheel and 1 for the black wheel and the last one was the top wide belt ... you did good .... :yes: :yes: :yes:
docs
2,558
381
United Kingdom
Hey, that's strange I only used 2 belts and it works fine.
The PRB line catalogue refers to 2 belts and 1 for the counter so I placed 2 belts in and it works, oh well.
Cheers for the input.
