I get no FM only AM Please help. Panasonic SG-J800
LLopez
490
:sad: Sad but true, I have a Panasonic SG-J800 It used pick up fm stations with no problems, But I stopped using it for while and no when I turn it on there is no fm reception. I tryed contact cleaner but no luck. Please help.
87
Another thing you can look at is the post lead for the antenna. My superscope had a loose post lead on the pc board and that was causing bad reception :-D
LLopez
490
:-D I'll defeanetly check out on it. Thank u so much for your help bbb I really appreciate it. :yes:
