OK,
I bought two 777's that have small issues and also have a couple differences.
(1) American box with AC cord and power supply.
-both of the tape decks work fine
-FM works fine
-SW1, SW2, and AM and they don't work for some reason
-back case is melted
-front case scratched pretty good
-missing tabs on the speaker cover
(2) European box with euro cord and power supply.
-both of the tape decks work fine but missing one cassette door
-FM, SW, MW, LW functions instead of SW1, SW2, and AM
-cosmetically perfect besides the missing cassette door
Basically I am asking if I should use the case, speaker covers, and other parts from the Euro box that doesn't have the radio bands I like to put on the american box? OR, should I take at least the cassette door and/or band selector, tuner display, and power supply from the american box and put it in the euro box?
I don't know what would be easiest to have 100% box with the american power supply and possibly the band selections I want...... Help if you can, thank you.
Will the SW, MW, and LW bands work in the USA? What are they compared to the SW1, SW2, and AM?
-FM works fine
