RX-C300 Low HUMMMMM noise
gnashing ferret
17
Brisbane, AU
Hi friends,
Bought a national rx-c300 last night, plugged it in n got a nasty low hum noise coming through all inputs. I tuned the radio to a space with no station on it and there's still a hum noise, even when i push the cd/aux button there is the same hum noise. when i turn the volume right down the spectrum shows noise coming through even though there's no tunes playing...
any ideas? :'-(
10,898
112
Maybe a bad amp or grounding problem. :huh:
I'm sure others will be able to offer more details.
gnashing ferret
17
Brisbane, AU
what would cause a grounding problem? the exterior of the box is completely scratch/dent free and there's no rust in any of the compartments, so it has had a good life. Though the red speaker clips on the back have snapped off n have to be held in with blu-tack. But no amount of fiddling with these wires stops it, so i don't think the missing clips are are problem because all they do it hold the wire in place just like the tack. :huh:
gnashing ferret
17
Brisbane, AU
Hi, yes that's the ebay one in brisbane. We did plug it in n have a listen but i didn't notice it til i took it home n noticed that every song had a similar bassline, n then REALLY noticed it when i turned it up n took it off a radio station. The seller did knock the price down a lot (i'm talking a lot, more than necessary, but who would say no?) for the broken speaker wire clips. I'll try batteries n try the deoxit if i can't work it out. Can't have it only working with batteries as it's a big heavy one that will probably stay in my room most of the time. Headphones i shall also try, i will also post a picture of the spectrum analyser as it displays which frequency most of the noise is coming from
Ferret man:
Low hum noise such as what you are experiencing is usually associated with either mains noise making it's way into the system, or a grounding issue, or broken shielded conductor on signal cables, or bad capacitors.
If the hum is experienced globally, then the cause must be common to everything and the power supply immediately becomes suspect because the PS is obviously common to everything. If you are only hearing the noise on one channel, then you know the power supply is OK because both channels draw from the same power supply. That is the simplest way to diagnose -- determine what is common to the problem and what is not.
So I know you said you will test the boombox on batteries but that is important. Because if you are hearing the noise on mains and not on batteries, the capacitors in your Power supply should be replaced.
Cleaning all the controls and switches may help -- especially the record bar because grounds are often switched on the record bar and poor connection due to oxidized contacts can present as a bad ground. Obviously, corroded wires, solder joints and such can cause much the same symptoms.
Then there is the shielded cables which are common to the tape deck head cables. Shielded cables typically carry low level audio signals from place to place. Low level signals are especially prone to RF interference. Insulating those signal wires with a grounded shield is a common design technique. If the shield conductor is broken or ungrounded, then the RF protection is no longer effective.
Capacitors also can fail in a system allowing unwanted noise to enter the system. Throughout the PCB, you will see capacitors all over the place. One characteristic of capacitors is their ability to pass high frequency signals to ground. This is called bypass and caps used to "bypass" is usually implemented in a circuit in parallel with a load between the supply and ground. Installed in this way, the capacitor blocks DC (allowing that signal to proceed normally through the circuit) but pass high freq ripple to ground cleaning the signal. In my mind, I'd rather replace all the caps than to test them all. The reason is that with the caps exceeding 20 years and approaching or exceeding 30 years of age, it makes very little sense to remove them from a circuit (to test) only to reinstall the old aging caps, even if testing shows that is has not failed.
I wish I could tell you specifically what and where to look but the RX-C300 is not a common boombox and has many many IC's and OP AMPS which are especially prone to ripple interference. But you are going to have to go and get your hands dirty on this one as I don't think there are any "experts" on this model. The general advice herein is the best I can do, without personally looking at it myself.
My course of action (in the following order) would be:
(1) Test unit on batteries. If hum is gone.... replace PS caps, including the small ceramic ones
(2) Thoroughly clean all controls and switches including the record bar switch
(3) Visually check for broken grounds and broken shield wire conductors
(4) Using DMM, check for continuity, especially on ground shield wires tethering different circuit boards.
(5) Consider re-capping the boombox.
gnashing ferret
17
Brisbane, AU
oh super superduper, thats the kind of answer i was hoping for :thumbsup: I shall try all those things and hopefully resolve it with the simple stuff. as i said it looks perfect so hopefully its nothing major. my old man said as long as its not the power supply it should be a fairly inexpensive fix, so fingers crossed! shall keep anyone who is interested up to speed on my progess and put photos into collections very soon :-D
gnashing ferret
17
Brisbane, AU
but where would i buy a new power supply for such an old box? i mean the supply inside not just the cord.. ok today i shall do all the tests to diagnose the problem ;-)
gnashing ferret
17
Brisbane, AU
Tested with headphone: still hum noise (so speakers are fine)
tested with batteries: hum noise gone (so it must be that power supply or something!)
Pulled it apart and had a bit of trouble getting to the power as it opens up from the front, so rather than pull all the circuit boards and stuff out I left it and put it back together. Since then the hum noise has disappeared and it's all working perfectly :thumbsup: There must have been some dust or something somewhere in there, and from pulling it apart and giving it a good jiggle it has come loose.
