Ok.. just an FYI.. i am not a Kaboom virgin.. i have owned at least 10 Kabooms over the last 12-13 years.. from the earlier B90-99's to the newest 1/10/20.. i did not own the DP100-200 but did listen to them at a Sears when they were released..
ok lets get to the meat and potatoes..
The sound..
this is not a classic Kaboom killer BASS wise.. BASS is slightly muddy.. not terribly muddy.. but it does not even come close to the deep bass the earlier Kabooms produced.. it's more of an in your face BASS.. a little dissapointed unfortunately..
it has the usual POP/CLEAR/ROCK ect.. CLEAR setting seems to be the best.. the ACS (auto clear sound) is not on this model either..
the locking mechs for the IPOD door and CD door are now spring loaded.. (cheap feel to them)
also this model was made/manufactured in CHINA... yes.. China.. unlike previous models that were made in malasyia..
and it shows.. it feels cheaper made than older Kabooms.. it's roughly the same size as older Kabooms.. and it does have a decent amount of wieght behind it.. but you know by feel/touch that it's not a typical solid Kaboom of the past..
also the guitar input and volume is gone.. the handle/strap also does not attatch like older Kabooms.. no metal pins/clips.. it kinda wraps around the openings on top instead..
it does feel cheaply made unfortunately.. the LCD display kinda reminds me of the new Lasonic's..
the volume knob and BASS knob have a more responsive click to them though which i like..
to give you an idea on cheapness.. there were no included batteries for the remote..
pics will follow..
The sound..
pics will follow..
