docs said:
Wondering if it is possible to bypass this kind of sensor, even for testing purposes?
I have a replacement incoming but it could take some time.
Hall effect sensors provide an output based on magnetic strength, so it's reasonable to conclude that the output from a properly working sensor, mimicking a rotating magnet would be some form of pulse, perhaps a square wave. However, I can't begin to tell you what the expected output strength would be. If you look at page 33 of the SM, it specifically says it is the magnetic sensor board.
docs said:
Replaced dm106 with an equivalent, 78L08, sadly same issue but with a difference being that if I hold finger on play/ff/rew it stays in position and works which it did not do before. Release finger and deck stops.
Seems to be a positive 3 terminal voltage regulator +8v, 100mA according to datasheets and equivalent options.
First off, it makes no sense that the item would cross to an 8V regulator. How and why do you think that the hall effect sensor is a voltage regulator? If you don't know the history of the boombox, you can't make that assumption that whatever component in there is a voltage regulator, IC, transistor, or what have you. You should go by the service manual. Secondly, if you look at how that device in used in the circuit, it is powered by an 5V rail, one leg to ground, and the sensor leg driving a transistor. There is 0.0% chance that an 8V regulator is intended to work with those circuitry complements. If the 3 leg'd item in there is currently a voltage regulator, someone in the past could have replaced the original hall effect sensor with one thinking that it "looks" about right. But then again, it could be any opto sensor, transistor, or any IC with 3 legs... Now, if you are going to cross the original sensor and can't find an exact match, I would say that it's probably better to try and find another hall effect sensor to try rather than stuff a completely improper component in there. IC voltage regulators are commonly used in virtually all electronic devices today. However, back in the era that this boombox was produced, the prevailing form of regulator circuit is the common collector transistor zener diode regulators, and this should have been sort of a clue regarding whether a VR belonged in that spot.
