Jump to content
Panasonic RX-5500 antenna
  • Please log in to reply
5 replies to this topic
#1 bantytfv
bantytfv
  • Members (SA)
  • 248 posts
  • LocationEast TN. USA
Posted 17 October 2019 - 12:09 AM
Anyone have an antenna for a RX-5500 for sale? Anyone????
#2 bantytfv
bantytfv
  • Members (SA)
  • 248 posts
Posted 17 October 2019 - 10:09 PM
*bump*
#3 bantytfv
bantytfv
  • Members (SA)
  • 248 posts
Posted 09 November 2019 - 07:35 PM
I found that a Tecsun PL660 radio antenna works quite well as a replacement, goes into the case nicely,very close to the original's length. Good quality as well.
#4 BoomboxLover48
  • Boomus Fidelis
  • 5,271 posts
  • LocationChicago, IL
Posted 09 November 2019 - 07:37 PM
Please check on ebay. You will get one that would fit. Some might take a while to come from China. Make sure the length is all correct and the segments. I was lucky to get nice antennas like that from ebay. You might get several ones for a cheaper price.
~Royce
#5 Jorge
Jorge
  • Members (SA)
  • 147 posts
  • LocationCalifornia
Posted 09 November 2019 - 09:12 PM
Great Tip, Million Thanks!!! Wish this thread can be moved to the TechTalk on Panasonic 5500...
I had the same problem, when antenna goes inside the case, it is next to impossible to find the substitute (how on Earth folks manage to break those!).
I followed "BoomboxLover48" advice and spent around $100 on different antennae off eBay, and ended up with making the following contraption:
Attached File  L1140902.JPG   71.75K   0 downloads
Attached File  L1140903.JPG   78.22K   2 downloads
Attached File  L1140904.JPG   49.4K   3 downloads
The end result looks decent, but definitely not as good as the original:
Attached File  L1150055.JPG   37.28K   1 downloads
#6 bantytfv
bantytfv
  • Members (SA)
  • 248 posts
Posted 13 November 2019 - 12:14 AM
Looks great to me.
