Jump to content
Looking for SHARP VZ-2500 phono motor
SHARP VZ-2500 VZ-2500
  • Please log in to reply
9 replies to this topic
#1 Funkateer38
Funkateer38
  • Members (SA)
  • 87 posts
Posted 20 September 2019 - 11:46 AM
Hello,
I am looking for phono motor in working order for SHARP VZ-2500 ( or SHARP VZ-2000 )
Let me PM
Thank you.
#2 Stuzy
Stuzy
  • Members (SA)
  • 117 posts
  • LocationLondon
Posted 21 September 2019 - 06:05 AM
Hi
Sorry, can't help
Have you tried Nikonfoo - Geoff
He may have  :yes:
PM him
#3 Funkateer38
Funkateer38
  • Members (SA)
  • 87 posts
Posted 24 September 2019 - 05:19 PM
Hello,
Let me PM
Thank you.
Attached File  s-l1600 - 2019-09-24T110810.727.jpg   23.39K   1 downloads
Attached File  s-l1600 (4).jpg   21.52K   1 downloads
Attached File  s-l1600 (5).jpg   23.3K   2 downloads
#4 docs
docs
  • Members (SA)
  • 1,923 posts
  • LocationUnited Kingdom
Posted 25 September 2019 - 02:20 AM
I dont think the other vz motors are the same. The service manuals have different codes and i dont think theyre wired the same since the 2000 uses a series of transistors for control and the 2500 uses an IC.
Whats occurring with it? Do you get correct voltages at q508?
Are the variable resistors which control 33/45 speeds checking out as 10k?
#5 Funkateer38
Funkateer38
  • Members (SA)
  • 87 posts
Posted 25 September 2019 - 03:08 AM
Thank you for your response. I disassembled my VZ-2500 and the engine has a different reference than the VZ-2000 even though it looks like.
My problem is that it doesn't work, it doesn't turn.
Attached File  20190925_103124.jpg   79.67K   1 downloads
Attached File  20190925_103147.jpg   63.86K   0 downloads
#6 docs
docs
  • Members (SA)
  • 1,923 posts
Posted 25 September 2019 - 03:25 AM
Problem could be q508 or the IC.
Need to check voltages at q508.
#7 JVC Floyd
  • Boomus Fidelis
  • 6,552 posts
Posted 25 September 2019 - 05:35 PM
Doc I have almost a complete record deck but it will take time because I have to look for the parts.
#8 Funkateer38
Funkateer38
  • Members (SA)
  • 87 posts
Posted 03 October 2019 - 11:54 AM
I took stock of my situation: Still not find a phono engine for VZ-2500.
So I tried to plug a vZ-3500 motor, the engine works but doesn't stop even with the switches.
#9 Funkateer38
Funkateer38
  • Members (SA)
  • 87 posts
Posted 09 November 2019 - 09:03 AM
 thought I'd find a replacement VZ-2500 engine with a slight reference difference of mine BFB2B91-20803-A instead of BFB2B91-20929-A but still doesn't work.
Why is the difference?
Attached File  s-l1600 - 2019-10-28T172648.450.jpg   76.63K   1 downloads
So i still looking for BFB2B91-20803-A . let me PM
#10 docs
docs
  • Members (SA)
  • 1,923 posts
Posted 09 November 2019 - 10:02 AM
I think they are internally different on the little circuit board inside the motor.
Also tagged with one or more of these keywords: SHARP VZ-2500, VZ-2500
