Jump to content
Looking for a Lasonic TRC 920 cassette door cover
  • Please log in to reply
16 replies to this topic
#1 BoomboxLover48
  • Boomus Fidelis
  • 5,254 posts
  • LocationChicago, IL
Posted 27 July 2019 - 09:39 AM
Please PM me if you have a Lasonic TRC 920 cassette door cover and screws.
#2 JVC Floyd
  • Boomus Fidelis
  • 6,552 posts
Posted 27 July 2019 - 02:20 PM
Royce I have the door cover in decent condition but I had to make the plexi glass myself, I dont have the screws because I used them on my 918.
#3 BoomboxLover48
  • Boomus Fidelis
  • 5,254 posts
Posted 27 July 2019 - 09:25 PM
Thanks so much dear Floyd!
:thumbsup:  :rock:    :hooray:
#4 JVC Floyd
  • Boomus Fidelis
  • 6,552 posts
Posted 28 July 2019 - 08:56 AM
Attached File  IMG_20190728_105147.jpg   32.32K   2 downloads
#5 BoomboxLover48
  • Boomus Fidelis
  • 5,254 posts
Posted 28 July 2019 - 09:00 AM
Wow! I cannot thank you enough!
:thumbsup:  :bow:
I am so grateful! :bow:
#6 JVC Floyd
  • Boomus Fidelis
  • 6,552 posts
Posted 28 July 2019 - 01:27 PM
No problem brother , my TRC 920 fell onto a concrete floor from 7 feet up and got wrecked . believe it or not even after the fall it still partially worked but I decided I needed the function switch for the TRC 931 I got from bill and I cut the tweeter horns out and mounted them in the front doors of my jeep with some high powered JVC tweeters.
#7 BoomboxLover48
  • Boomus Fidelis
  • 5,254 posts
Posted 28 July 2019 - 09:34 PM
Thanks so much bro! :bow:  :thumbsup:
#8 baddboybill
  • Boomus Fidelis
  • 10,991 posts
  • LocationHudson Florida
Posted 28 July 2019 - 10:43 PM
Hey Floyd are you parting it out? If so I’d love to get tuner. All I need is band switch as long as it’s 4 band?
#9 JVC Floyd
  • Boomus Fidelis
  • 6,552 posts
Posted 29 July 2019 - 02:01 AM
Bill the band switch is shot. The tuner board is shot, that part took the most damage.
#10 baddboybill
  • Boomus Fidelis
  • 10,991 posts
Posted 29 July 2019 - 02:13 PM
The band switch by shot? What happened to it?
#11 JVC Floyd
  • Boomus Fidelis
  • 6,552 posts
Posted 29 July 2019 - 02:26 PM
Bill I have the tuner board but what I did was cut the top off of the band switch and used jb weld to hold it in the FM position , i do remember the tuner was working but not tuning all that well so I can't promise anything.
#12 BoomboxLover48
  • Boomus Fidelis
  • 5,254 posts
Posted 11 August 2019 - 09:25 AM
HI Floyd,
The door arrived well packed. The Plexiglas you made shows how good you are with your hand work and craftsmanship! :jawdrop:  You are AWESOME!  :thumbsup:
Now I am looking for those screws for the Plexiglas door and a headphone jack.
The headphone jack was all cracked and pieces fall inside it.
After getting those screws and headphone jack, box will look like new.
#13 baddboybill
  • Boomus Fidelis
  • 10,991 posts
Posted 11 August 2019 - 11:30 AM
Floyd is Awesome the door looks great!!
#14 JVC Floyd
  • Boomus Fidelis
  • 6,552 posts
Posted 11 August 2019 - 11:51 AM
Awesome glad you like it , I do have junker boxes I can pull a headphone jack from . not lasonic but should mount the same way.
#15 BoomboxLover48
  • Boomus Fidelis
  • 5,254 posts
Posted 11 August 2019 - 01:28 PM
Thanks so much!
. I don’t think not many people can work like how he does. You should see how precise he cut the plexiglas to utmost perfection! I thought I was good ..... but I take it back seeing his work!
#16 BoomboxLover48
  • Boomus Fidelis
  • 5,254 posts
Posted 11 August 2019 - 08:37 PM
Finding screws for the door became another puzzle!
I had to make two trips to the nearest ACE Hardware store. Found mini thread stainless steel screws with Allen Key head. It looked so good on the door.
#17 JVC Floyd
  • Boomus Fidelis
  • 6,552 posts
Posted 12 August 2019 - 04:10 PM
Thanks so much!
I made 4 tuner windows for m90's out of that same thick plexiglas. Also made one for my TRC 918 but that was the last of it.
