GF-999 speakers cutting in & out
moshenskmz
So now Im tackling my second gf999 ... which has a few issues, first of which is the balance knob seems not to function? And the speakers themselves tend to cut in out from side to side depending on volume level. Any thoughts on as to what might be causing this? Thanks again guys
10,900
129
Definitely dirty potentiometers. It seems to be a thing with these models eventually. The volume pot on my GF-777 is especially prone to getting dirty, and the balance pot seems to never work 100% correctly.
moshenskmz
Thanks for moving to new topic... sorry about that I will do so next time as well... ok il take a crack at cleaning those ( I'm assuming I need to access these from the back correct? ) Thanks man
Josh9994
21
12
42
AZ, USA
You will need to pull the controls for a thorough cleaning, however you can pull the knobs and give them a spray of deoxit through the hole in the top of the potentiometers.
10,900
129
While that can work in some instances, the proper way - as you mentioned - is to pull the controls out for cleaning. :-) :cool:
5,756
274
The spray through the hole might work, but not the right way of doing things. It will over spray on the nearby components, will also flood the potentiometer area, and remove all the lubrication. Then the shaft will turn with no feel/resistance to it at all.
