Jump to content
Sansui Cp R7
  • Please log in to reply
No replies to this topic
#1 Guest_ab123_*
Guest_ab123_*
  • Guests
Posted 06 January 2019 - 02:15 PM
Hi, I have just acquired one of these, knowing very little about it.
The tape function and amp is working fine, really belts out some volume, but the tuner display is apparently dead, the tuner is working but no display
Also the tuner memory buttons feel decidedly unresponsive, but I cant check whether they work due to aforementioned display problem. Ive had it apart to replace the blown back light bulb for the display but cant find any reason for the dead display other than general age related lcd stuff.
I dont suppose anyone knows a source of these displays?
I have found them listed on .sansui-parts-shop. com  but they are out of stock.
Or if not whether any other displays could be compatible with this model?
If I can figure out how to get the control panel off the front,  I think I can manage to replace the tactile switches for the memory buttons, but with no working display, there isnt much point.
Any ideas welcome.
Cheers Al.
