So the second problem! when I bought the box I knew this was a problem I don't know if anyone has a great hypothesis, I try to deoxit the switch but it seems like that might not be the problem. When put on tape function without having the tape playing a loud hum buzzing sound can be heard! I can play with the switch which will make the buzz signing differently! is this simply a bad switch that needs to be replaced or should I look for something else?
Thank you again guy for the help !!!
