Hi all:
My name is Mike and I've been sort of a failed, virtual boombox fan since a few years ago when I bought a nice little aiwa unit that I failed to fix myself or get get fixed affordably, and sadly left at the repair shop after paying for an estimate.
My son badgered me into buying a Magnavox D8443 at the thrift store the other day and everything works (except the tape counter and I haven't tested its ability to record). It's pretty, sounds good, and seems a fine place to start.
Research tells me that I'm lucky the tape player works--that a specific gear hasn't broken. Apparently I can buy a new one--maybe I will, preemptively.
But is there anything I can do now to keep it working? Is there any "maintenance" that a technically-challenged person could/should do?
And it's missing two buttons--the play and the rewind, I believe. What would folks suggest I do about that, long term? Are they easy to replace if you have the parts? As people are trying to sell non-working versions of this thing for almost 100 dollars on ebay, maybe there's another model with the same buttons...
Thanks for sharing your supportive and informative community.
