Adjusting Azimuth on GPO Brooklyn
Transistorized
1,838
265
Ok guys. The Azimuth needed a slight tweak on my Brooklyn. Our vintage blasters have a door that easily pops off or a slot under the door that you can access the screw.
Well the Brooklyn doesn't. You must gently pry the front plastic window off the front of the door to access the screws holding the front door cover. Remove screws and front door trim. Then place your tape into the inner skeleton tray. Press play and use the Azimuth adjustment slot to take care of business.
Now my Brooklyn is as crisp as can be while playing a cassette.
10,898
112
Nicely done! I'm impressed that the GPO has a digital tape counter.
Just out of curiosity, how do you know where a knob is indexed? They don't appear to have any notches or indentations. Or am I just not seeing them?
Transistorized
1,838
265
That's actually a great question. The lettering on the box is just for show. When you turn the volume, balance, treble or bass knobs the screen at the top shows you what number you are on digitally. However, once you have completed the adjustment the screen jumps back to the function you are on and at that point the only way to know where you are on the indexing is to turn the knob again and reference the screen.
The scoop on the digital tape counter:
The digital counter for the cassette is not controlled by the cassette deck mechanism. As soon as the tape deck is powered up it starts counting like a timer and has a reset button.
11,091
84
I just got my GPO Brooklyn and love it. The size, feel and quality and sound are pretty darn good. Honestly one of the closest Boomboxes to the original ever built in the silver 1 pc box era!!! So why did you have to adjust azimuth already. Just curious?
1,262
278
Melb AU
Was that cover damaged when you removed it? Just thinking if you could record the exact measurements a small pilot hole instead? Right in the midde of the O in Auto?
Transistorized
1,838
265
Great question. Well...I had noticed that my tapes sounded dull only in the Brooklyn. I am guessing it was never exact from the factory. I knew my tapes were in top order. While playing a tape I made a slight clockwise adjustment and the clarity came right in. Went from semi muddy to very crisp.
It sounded "ok" and if I didn't already know how my tapes sounded and didn't have any other boxes to compare it to I probably wouldn't have paid much attention.
Others may not need to do this but I am very picky on my cassette decks. Surprisingly enough I am happy with the tape speed.
11,091
84
Cool 😎 I’m gonna check mine
TW5
277
I did an azimuth adjustment by opening the door
and inserting the test tape with the door open
and reaching the screw from under the door
not sure if that will work with this box
I think the Azimuth adjustment all boils down to Quality Control at the factory in my opinion maybe the workers just aren't familiar with tape decks.
