Jump to content
TRK-7620H Tuner Repair
11 replies to this topic
#1 bodaddio
bodaddio
  • Members
  • 13 posts
  • LocationNew Orleans
Posted 23 April 2018 - 01:44 PM
Hey everyone, thank you for taking the time to read this. I have found this box and it works great, but one problem. The tuner needle does not work. I have taken it apart and it seems one of the pulleys broke. I am working on fixing this, but have no idea how the string is routed. Does anyone have a picture or a diagram of this routing? Anything that can help me out?
Thanks Everyone.
#2 T-STER
T-STER
  • Members (SA)
  • 2,163 posts
  • LocationUK
Posted 23 April 2018 - 01:51 PM
I would grab the manual from somewhere reputable such as here:
https://www.analogal...roducts_id=2090
#3 jimmyjimmy19702010
jimmyjimmy19702010
  • Members (SA)
  • 3,563 posts
  • LocationSunny Brisbane, Australia
Posted 23 April 2018 - 03:28 PM
I’ll grab a pic of the tuner string page of the manual tonight.
If you need further information regarding this box, I’d also suggest you get one of Norm’s manuals.
#4 bodaddio
bodaddio
  • Members
  • 13 posts
Posted 23 April 2018 - 08:17 PM
You guy are awesome! Thanks for the link. I really appreciate it.
#5 jimmyjimmy19702010
jimmyjimmy19702010
  • Members (SA)
  • 3,563 posts
Posted 24 April 2018 - 05:00 AM
Pics of manual as requested:
Attached File  CA839F5A-3481-4E43-9F05-1645723EDAA0.jpeg   60.73K   4 downloads
Attached File  85571A22-65C9-43AA-8D23-3B354AF55841.jpeg   46.63K   3 downloads
Attached File  50DBEA2A-6798-4A2E-A51A-3D7F5E6F2405.jpeg   42.52K   4 downloads
#6 metalhandbag
metalhandbag
  • Members (SA)
  • 434 posts
  • Locationuk manchester
Posted 24 April 2018 - 06:53 AM
Result nice one Jimmy.
#7 bodaddio
bodaddio
  • Members
  • 13 posts
Posted 24 April 2018 - 07:51 AM
Thank You Jimmy! You saved the day! Ill have to buy you a beer.
#8 bodaddio
bodaddio
  • Members
  • 13 posts
Posted 24 April 2018 - 09:15 AM
OK next question as you can see from my picture the pulley between 4 and 5 is broken. I have most of the pieces but gluing back together is proving to be a chore and I am afraid it is just going to break again. Has anyone found a good way to fix this problem?
Thanks again guys.
#9 jimmyjimmy19702010
jimmyjimmy19702010
  • Members (SA)
  • 3,563 posts
Posted 24 April 2018 - 04:30 PM
I wouldn’t bother trying to repair the old string as it’s under a fair amount of tension. I normally use a string from a parts box and just adjust the length to exactly match the old string (luckily you still have the original for measuring purposes). The thickness of the string should, in an ideal world, be similar to the original.
Not sure where you would find new string commercially. Maybe someone here can help with a supplier.
Don’t forget to apply a little lube to the pullies (don’t get any lube on the string)!!!!!!
#10 bodaddio
bodaddio
  • Members
  • 13 posts
Posted 24 April 2018 - 06:19 PM
Hey Jimmy, sorry I may not have been clear. The string I have is in great condition, no problem at all. It is the pulley that is the problem. If you look at my picture bottom left, there should be a pulley there. The plastic housing exploded into about 10 small pieces. I am trying to figure a way to repair that.
Thanks.
#11 jimmyjimmy19702010
jimmyjimmy19702010
  • Members (SA)
  • 3,563 posts
Posted 24 April 2018 - 06:54 PM
Normal super glue should be used to piece the bits back together. Then the whole area should be smothered with JB Weld. Let it dry over a 48 hour period before loading the string. Remember, the super glue is only used to hold everything in place to give the JB Weld time to cure. The repair will look like crap but it’s internal so no one will ever see it.
I used this method with some screw posts on my TRK-7620 with excellent results.
#12 mika
mika
  • Members
  • 1 posts
Posted 01 June 2018 - 07:43 PM
