Ha ha thanks, but it's only a bassy midsize, it's not one of the bassiest boxes in general. For that, you're gonna need one of the bigger Lasonics, Conions or TecsonicsGnarlyman said:JVC Floyd, you knew exactly what I was thinking, that TRC-920 is sick. probably gonna be hard to find but looks worth the search.
The first one that popped on Youtube was Reli's with the mirror bowl tape, dope as hell!
I can promise you I’m not high.Rimmer36 said:jvc rd md5 beats the dp200, sorry Norn .....jimmy what are you smoking lol....i want some
Yep, you’re right. He was after classic 1 piecers - unfortunately, that’s not the format for the strongest bass.Hisrudeness said:Are kabooms and platinum Panny’s, Hitachi 3d’s after 1985?
I think threadstarter wanted info on the classic 1 piecers.
you have sold me, im after a 3d 8 loljimmyjimmy19702010 said:The 3D7 can’t match the 3D8 for bass - the 3D7 is bassy but the 3D8 is next level.
I’ve had 5 680s and I’ve tried every slider/SBS position combo and well, the 3D8 still goes deeper.
Don’t ask me how or why but a 12V 3D8 does go deeper - maybe it’s the long throw 16cm main driver that sits in a huge cabinet?!77433350-59E4-4147-908A-73DF119E60D3.jpeg
It must be the bigger driver. Maybe that’s why everyone rates the sound from the Panasonic C100 over the 680 - bigger 16 cm drivers?!
ahh the 680 sounds better to me than the 100 Jim but the 100 is louder and it's silver.....basically you can't compare the 2jimmyjimmy19702010 said:The 3D7 can’t match the 3D8 for bass - the 3D7 is bassy but the 3D8 is next level.
