In the battle of large boxes that "Fight the Power" it is a great day to be alive. Technology might be extreme in some cases but very much helpful in others. When you have large boxes you need Power. I don't like the idea of being tethered to a cord. Just doesn't let you enjoy the box the way it was intended.
But D batteries (then and still) are expensive, leaving you to try and locate that one special place (outdoors or indoors) where you can plug in.
While expensive in the short term (price wise) these will SAVE YOU in the long term. Especially if you demand extended playback that rivals the traditional Alkaline battery with a way less chance of leakage (if ever). Even if left for years in your blaster.
Just got another 10 of these for Christmas. I now have 30. This means I can grab just about any machine off the shelf, go to the B-Ball court or any outside event and know that I have an EASY 14 hour playback with 100s of reliable recharge cycles.
If you haven't tried them you really should get these with a good smart charger. You will be glad you did. With 10,000mAh you have the same or better playback time per charge than a standard Alkaline battery. You can tell they are packed with power. They weigh the same as an Alkaline battery. Not prone to leaking they're great!
Anyone else use these?
