What other models fit the outside speakers? I have a 770, but dunno if they will work.. will have to take it apart and see... I need to have chrome centers on whatever I replace it with.....
A good idea to make a passive (basically a dead speaker that helps generate more pressure/hence bass freq's) Is to find a nice speaker and cut a poster board (2x-3x thick) liquid cement them together and bond it the speaker on the inside of the foam lip (I use black rtv silicone, looks good ad holds great) you can paint the center a nice silver color and be done with it, factory NO...sounds good and looks even better... did it years ago on a wx1 project.
