Jump to content
Sony CFS-W600 belt size needed
  • Please log in to reply
2 replies to this topic
#1 Reaper83
Reaper83
  • Members
  • 5 posts
Posted 07 September 2017 - 04:55 PM
I need to know the part number of the belt to fit a Sony CFS-W600.  I couldn't find the service manual or any parts list for this model anywhere.
#2 Reaper83
Reaper83
  • Members
  • 5 posts
Posted 07 September 2017 - 05:25 PM
I just found the service manual.  The Sony part number on the belts are 3-313-389-01.  This belt also fits a CFS-W500S.  Does anyone know what belt number (SBS#, SBM#, etc) this would cross reference with?  I couldn't find one online anywhere with the Sony part number.
#3 davebush
davebush
  • Members
  • 309 posts
  • LocationSunny Blackpool. UK
Posted 08 September 2017 - 11:30 PM
there is one here but its expensive.....
Try fitting some string round the belt path....that will give you an idea of its length....then search ebay for similar sizes....cheaper too..
If your in the UK try here    http://cpc.farnell.c...searchlookahead
http://spares.bigwar...ducts_id=246508
