Dear members and followers,
today i fixes as good as i can my VINIX and so far so good. I solved the problems with the VU Meters and they works fine now.
But i got a problem with the right channel when i play a tape. Radio works very well and when i record something and
use the mic mix function also.
But when i play a tape on the right channel you can only hear a hum.
Also when i record and after that i play the tape is only what you can hear a hum. Not when i use the radio.
Balance works also good. Only in playmode.
Is there anyone who can help me with this??????????
Where could be the problem located?
And a additional prob: I dont know if its right but when the tape is rewinded the tapedeck doesnt stops then automaticly.
Is this ok? And it is too slow......The speed is to slow. Is this why the belt is not correct? I have change it cause the original was to
long with the time. My new not original is smaler.
I would be gratefull for all your help
