exlusive
redbenjoe I Am Legend May 6, 2009 17,993 9 0 83 florida Aug 21, 2017 #1 exlusive Attachments e clips.jpg 47 KB Views: 2
Radio raheem Member (SA) May 13, 2009 4,959 908 113 uk Aug 21, 2017 #2 These little critters have saved many boomers and are plentiful on the bay
Lasonic TRC-920 Moderator Feb 16, 2010 14,130 102 48 55 Naples, Italy Aug 21, 2017 #3 Oh that sound of "Ping, Pewwww" as it disappears into the dark corners of the garage!
caution Member (SA) Mar 25, 2014 2,506 341 83 Boomboxery Aug 21, 2017 #4 I was surprised to see that Harbor Freight sells e-ring kits with the teeny tiny ones. Or, tear apart a couple decks and you're set for life
MyOhMy Member (SA) Jul 26, 2015 2,509 7 0 71 Sleaford, Lincolnshire, UK. Aug 21, 2017 #5 Lasonic TRC-920 said: Oh that sound of "Ping, Pewwww" as it disappears into the dark corners of the garage! Click to expand... Of course, there's also the ol' beads of sweat just waiting to drop 'cos you know it's going to happen, doncha, huh?
JustCruisin Member (SA) Jan 28, 2012 3,100 17 38 Midwest, USA Aug 21, 2017 #6 Lasonic TRC-920 said: Oh that sound of "Ping, Pewwww" as it disappears into the dark corners of the garage! Click to expand... love the sound effects!
THAFUZZ Member (SA) May 5, 2009 3,419 30 48 Midwest, USA Aug 22, 2017 #7 JustCruisin said: Oh that sound of "Ping, Pewwww" as it disappears into the dark corners of the garage! Click to expand... love the sound effects! Click to expand... Exactly!
