Question regarding Hitachi TRK 7100H
BCro89
4
Is anyone familiar with this boombox? I'm trying to hook up my phone to it via the Line In and can't figure out how to get it to play.
Any one have any pointers? Can provide pictures if that helps.
Check the function selectors to see if there is an aux input setting. You can also use a quality cassette adapter
.The cheap ones are useless.
BCro89
4
goodman said:
Function - tape, insert cassette and push REC.
Now you must listen sound from Line In. :yes:
Tried doing this an was sadly didn't work. Any other suggestions?
May just have to buy an FM transmitting and plug it in to my phone and play off the station.
