Crown 850l Strange noise when i power it on
label321
97
8
Hello people,
I have a Crown 850l with the problem that if I sometimes start him that you hear a noise, then you can not receive any channels normally.
Feather does he work perfectly when you turn it off and then it's possible that the power button is dirty? I like to hear it!
Greetings label321
6,316
441
I've owned 6 of those radios, and 4 of them had that problem. A long period of static after powering on. And again after powering off. I suspect it's a bad capacitor. You would need to identify and replace that capacitor.
label321
97
8
And you know witch capacitor it can be?
label321
97
8
Reli said:
No, I never tried, sorry!
So it can be every capacitor...
I must check for leaking capacitors or check them with a meter device?
I never replace a capacitor or use that device
but each capacitor has a value and if its lower or the capacitor is leaking somethimes you can see it right?
