O.k.here's my problem,its weird.So I've got this cheapo Panasonic rx-4830.It doesn't work when plugged in 😔 but does work on batteries.I can't figure out what the prob could be.Any ideas?
Exactly! Or a fuse blown on the primary of the power transformer / damaged power supply.baddboybill said:Does the cord plug into unit or is it attached always? If it has to be plugged into back or side of Boombox then issue might be the micro switch that is built into it has bad connection due to dirt or corrosion.
Bad Boy Bill
