Well my friend did a GREAT job on my M-90! He opened it up and cleaned it completely inside. He had to align the FM band which had 21 pots to adjust. He also got the deck out of the box and cleaned and oiled the motors. New fresh belts were installed. Before I had it someone went in there and bent the metal plate in the back.Took 12 hours to do all that needed to be done. Cost a pretty penny, even with me "friend" discount.
He also made a tone test tape with a scope.. So he could perfectly adjust the tape deck speed.
The FM sounds fantastic. .Crisp clear with great base. The stereo works now and has a great natural separation.
The tape deck sounds great and has NO WOW OR FLUTTER!
But it still has a problem that he could not fix a tape starts playing and plays fine. But when I go to press stop. The deck starts making a chattering sound. The audio goes off but the tape still plays and the meters still move. Deck will not respond to pressing STOP FF REW PAUSE. Sometimes not even to pushing the power button. One has unplug the the unit or take out the batteries if using on battery power. The the heads will disengage and drop, when it is plugged back in or batteries put back in. Then the deck plays fine.
It used to happen only when it got to the end of the tape. But now it can happen more at any point during playback . Any thoughts on this problem? Anyone else have it happen?
MyTech friend who worked on it says
One of the plastic gears, is slipping and the teeth are worn. He said it is attached to the flywheel so it is impossible to replace. So one would need a ENTIRELY exact same deck, to fix the problem.. I believe that the M-80 has the same exact auto logic tape deck as the M-90. So he says if I can get one with a good tape deck and the gears are all good, no wear (like on mine) he CAN swap out the deck from a good M-80 and put in My M-90
I would Love to get a M90 that is Dead but has a good tape deck to replace the cog worth paying some $$ Any help is appreciated
Take Action
Take Action
