Jump to content
Sony fh150R + APM 177M worn foam speakers
3 replies to this topic
#1 eggon
eggon
  • Members
  • 3 posts
Posted 15 December 2015 - 09:54 AM
hi everyboby,
thanks for accepting me on the community ...I' m French and i'm 37
I'm the lucky owner of a sony fh-150r and a pair of APM 177m.
As many of other owners like me, i have to replace the foam of the speakers wich are very worn
I've seen the other similar topic on the forum , started by 1fst .
https://boomboxery.c...er-repair-help/
My question is: is that the speaker dimensions are the same on the APM177 and APM158  ?
I was wondering so, because as on the ebay link pointed by LVJ there's no indications about compatibility between 158 et 177 and the description is for sony fh15 and apm 158, so i don't want to order the wrong reference.
if any member could give me any informations about compatibily with those 2 models, i mean about the foam size , thats will be cool ....
thanks in advance
Eggon
#2 davebush
davebush
  • Members (SA)
  • 309 posts
  • LocationSunny Blackpool. UK
Posted 15 December 2015 - 03:50 PM
think i bought these for my 177`s...check with the guy before you buy
http://www.ebay.co.u...=STRK:MEBIDX:IT
#3 eggon
eggon
  • Members
  • 3 posts
Posted 15 December 2015 - 10:31 PM
Hi davebush,
thanks for fast reply , i just sent a message to the guy of speakerparts to see if the foam you linked me will matching
my 177's ...
will tell you if so , asa i'll get a reply
thanks again
#4 eggon
eggon
  • Members
  • 3 posts
Posted 19 December 2015 - 11:04 AM
Dave Bush, the seller ask me to provide him the 4 dimensions of the foam , but from what I saw , the link that you provided me should be the right
I just measure the dimensions of my speaker, it's all matching ( not asbolutely sure for the B value, as I mesure 10,8mm instead of 10,9mm, but i think it must be the same)
