Sony SX-2990?
BionicPanda
6
I'm about to buy a Sony boombox. Double cassette deck, AM/FM/SW radio, line-in, 3-band equalizer. The seller claims it to be a SX-2990 Double Deck. But I couldn't find anything related to it on Google. Judging by the pics, it seems to be a Sony CFS-W350 with 4 bands instead of just AM and FM. Does anyone have the sepecifications of it? (sound output, wow & flutter, etc.) Thanks in advance.
goodman
2,330
236
50
Bulgaria
Hello. I see that you are new to the forum.
I suggest you look around in antique shops.
If you do not find anything interesting then look on the internet.
This Sony is cheap and low quality radio.
My advice is - do not buy it.
Here's some much better proposals -
These are quality radios with great features and good sound:
http://articulo.mercadolibre.com.ar/MLA-578325292-radiograbador-boombox-jvc-rc-656jw-biphonic-japan-1982-_JM
http://articulo.mercadolibre.com.ar/MLA-585876124-minicomponente-radio-jvc-pc-w300jw-pc-ghetto-blaster-boombox-_JM
http://articulo.mercadolibre.com.ar/MLA-578079069-radiograbador-ghettoblaster-sharp-qt-37z-boombox-japan-1987-_JM
PS: Is prices in this site is in US dollars or not?
MyOhMy
2,509
7
Sleaford, Lincolnshire, UK.
I would agree with goodman on this. I was (and still am) a big fan of Sony in the 70's, the build quality and the sound quality were always without disappointment but I think they made a subsequent mistake by lowering standards to pursue the mass market.
gooman's first link is to a JVC RC-656 and many a time had I read of the sound quality of this BB - so I bought one and can honestly say that it lives up to all the sound quality claims made, the listening experience is fantastic for a mid-size box.
The third link is to a Sharp Qt-37 and I can only repeat my words above. I acquired one of these very recently (see post here) and find it incredible for a small BB - (although it's quite a large small BB!).
In short I'd suggest walking away from the latter day Sony and follow good advice from goodman! :thumbsup:
BionicPanda
6
Thanks for your suggestions. The prices of Mercado Libre are in Argentine pesos. Unfortunately I can't afford anything more expensive than this Sony, I just need a system with a working cassette player and line-in.
MyOhMy
2,509
7
I understand what you're saying, I often find myself in the same position but it is well worth the wait - even for just a little time. Another thing I've noticed on 'some auction sites' or sale sites is, when a box at the 'less expensive end of the price range' is offered and there are no takers, it's usually re-listed at a lower price so that's when to pounce on a bargain. Wait just a little while - if you can - and your patience may be rewarded!
duckman
626
Dead Center, Manitoba, Canada
Being older however, there is a good chance the cassettes won't work properly, or for long if they do. If you are handy it can be fixed, but if not . . . . Just saying.
Is this a local sale?
BionicPanda
6
The seller is in a nearby town. He assured me that the boobmox is in perfect condition. I'll go check it personally tomorrow. If it doesn't convince me, I won't buy it.
RossHunt
[SIZE=11pt]Hi,[/SIZE]
[SIZE=11pt]I also want to know the specification of Sony Boombox. I [/SIZE][SIZE=11pt]am [/SIZE][SIZE=11pt]really glad to check the specification of the system. Goodman is right[/SIZE][SIZE=11pt],[/SIZE][SIZE=11pt] the sound quality of this system is so bad. Thanks for [/SIZE][SIZE=11pt]the [/SIZE][SIZE=11pt]awar[/SIZE][SIZE=11pt]e[/SIZE][SIZE=11pt]ness[/SIZE] [SIZE=11pt]to buy this system.[/SIZE]
[SIZE=11pt]----------------------[/SIZE]
[SIZE=11pt]Thanks and Regards[/SIZE]
[SIZE=11pt]Ross Hunt[/SIZE]
India Software Development | India Web Development
