Jump to content
Fisher PH-D715 AC Power not working
AC Power Not Working
  • Please log in to reply
2 replies to this topic
#1 zmkm
zmkm
  • Members
  • 1 posts
Posted 15 July 2015 - 02:52 PM
I have a Fisher PH-D715 boombox for years, it worked fine with AC cord plug-in until recently, the AC power was no longer working.
This unit allowed three power inputs, 120 v AC, 12v DC and 8 D Battery pack.
The unit can still be operated with Battery but not with 12v DC adaptors, I tried 12v 1.25am, 12v, 5am (there was no indication of what am rating was required and I do not have the manual to find out).
I would like to fix the AC power unit or find a correct 12v DC adaptor, any suggestion? Thanks.
I have opened the box and taken 3 photos: the power unit is on the right, close-up view of power unit and circuit board.Attached File  IMG_0767.JPG   41.48K   13 downloadsAttached File  IMG_0768.JPG   36.7K   12 downloadsAttached File  IMG_0769.JPG   35.63K   10 downloads
#2 Superduper
  • Boomus Fidelis
  • 6,167 posts
Posted 15 July 2015 - 03:47 PM
These boomboxes typically have switched receptacles to ensure only one power source is connected at a time. That means each jack has a microswitch, usually inside the jack. Spray the heck out of them with electronics cleaner while working them to clear that up. The contacts corrode or oxidize over time preventing good contact. That's probably your issue.
#3 stereomann
stereomann
  • Members
  • 253 posts
  • LocationMD
Posted 15 July 2015 - 09:23 PM
I have the same box i can sell it to you if you want it the cd & tape deck dont work on it but the radio does & it works on AC power
