Jump to content
Crown 970 Tape Speed Adjustment
  • Please log in to reply
7 replies to this topic
#1 alfie
alfie
  • Members
  • 1,328 posts
  • LocationSydney, Australia
Posted 04 April 2015 - 09:20 PM
Hey Guys,
Does anyone know how to adjust the tape speed on a crown csc 970 if it's playing too fast? Belt size isn't the issue btw.
Any help would be greatly appreciated!!!!!!
#2 JVC Floyd
  • Boomus Fidelis
  • 5,164 posts
Posted 04 April 2015 - 10:42 PM
is there a hole on the motor to adjust the speed?.
#3 alfie
alfie
  • Members
  • 1,328 posts
Posted 04 April 2015 - 11:13 PM
Had a look but couldn't see one......
#4 Michiel
Michiel
  • Members
  • 192 posts
Posted 05 April 2015 - 06:03 AM
I didn't find a way to adjust the tape speed in neither of my crowns. Got the 950, 850 and 980. Crowns are low end boxes I guess. Maybe you can replace the motor for an adjustable one?
#5 alfie
alfie
  • Members
  • 1,328 posts
Posted 05 April 2015 - 05:18 PM
Thanks Michiel, sounds like a lot of work.
Surely there must be a way to adjust the speed.....?
#6 toshik
toshik
  • Members
  • 420 posts
  • LocationSt. Augustine, FL
Posted 05 April 2015 - 05:26 PM
If I remember correctly pre-1980 motors had electro-mechanical regulator with torque levels-centrifugal switches combination. They were factory-adjusted and then sealed inside the double motor cases.
Later ones got a normal motor regulator with pot hole.
#7 Nickeccles
Nickeccles
  • Members
  • 342 posts
  • LocationLittlehampton West Sussex
Posted 15 March 2017 - 02:01 PM
All these Crowns have a speed adjustment under a white sticker on the underside (take the front off any of these & you will see it) they are so easy to adjust!! My 850, 950 & 960 all have this type of motor
They are electronicly controlled by a servo circuit inside the motor like almost all 80's decks........
Here are the 950 & 960 inside - there is a small hole under the white sticker & the electronic pot to adjust the speed is accessible through the hole :-)
The 850 has a different deck but the same motor..........hope this helps!!
Even though the 970 has a soft touch deck, the same applies to adjust the speed!
Attached File  Crown CSC 950L Radio Recorder Restored - 16 January 2016 (3).jpg   100.05K   2 downloadsAttached File  Crown CSC-960L Radio Recorder - January 2017 (37).jpg   139.36K   2 downloads
#8 Rimmer36
Rimmer36
  • Members
  • 2,352 posts
Posted 22 May 2017 - 01:50 AM
nice one Nick :yes:
