Got home and have been enjoying the
Mighty M90 I have experienced
Some intermittent problems with the tape
Deck. When I push stop from playing a
Tape. A loud chattering sound can be heard.
The deck still plays and the meeeters still
Move. But no audio is herd. Pushing
Stop will not dis-engage the deck. The
Power button will not turn off the radio or
Stop the deck from moving or making
The chattering sound. Only taking out
The batteries ( I don't have the correct
AC cord) will stop the deck .
Then upon powering up the radio . The tape
Deck will work as it should.
Could a slipping belt be causing this? Or one
Of the deck motors or both , needing service
( cleaning oil ) maybe the fusible resistors need
To be replaced
This happens occasionally .
Thank you for the help
To be replaced
