Just double checked and mine is the 7900L...so the K has soft eject but the L doesn't?...that's weirdbaddboybill said:Yes the 7900K has soft eject
Bad Boy Bill
Ok I thought so. The little black canister that is responsible for this function on mine is spewing oil (or some thick liquid) out of it and it is not working as such. Maybe take it apart and see how the innards work?baddboybill said:Yes the 7900K has soft eject
Bad Boy Bill
Ah, got it. Looks like mine is all leaked out of that case but its more of an oil. I don't see any adjustments that can be made. Probably just fill it with a thicker viscosity grease to help the situation.baddboybill said:It should have a grease inside and there is an adjustment screw as well
I sure know that feeling.Northerner said:Dammit...another thing to fix lol
