Sharp gf-9696H owner manual
Tuck
6
Hi guys,
I recently found this sharp Gf-9696h, saving it from the trash!! It is in a very good state and seems working good but I really dońt know how to use it!
Does anyone could share the owner manual (not the service one)?
Or maybe explain me how to simply turn on the tuner?
The only way I found is to push on the play button with tuner mute off, the tunner works very fine(and the sound is great!!). But after a few seconds the button jump off and the radio stop;(
Thanks for your help
Tuck
6
Thanks for your quick answer jimmy,
I already did that. Nothing happended.
Only when I push the play button I have the leds lighted on. I have "power" "mixing" and "stereo fm" lighted when I push on the matching buttons. But as I sayed, after a few seconds its stop.
Also, the the tape is not turning. Only when i push the fast fwd and rwd.
Any idea?
Tuck
6
I already did that. Nothing happen.
Any idea?
Tuck
6
I finnaly found a way by pushing on the pause with the play. Don't seem to be the normal way but working!
Still looking for the owner manual anyway...
jimmyjimmy19702010
3,578
26
Sunny Brisbane, Australia
Any idea?
Sounds like you have a faulty on/off switch - common problem with that model. I repaired this very same switch on a friends 9696 with the same problem last week.
Tuck
6
Beosystem10 said:
There's a manual at hifiengine HERE. :-)
I'm seeing that library page as signed in, you may need to join if you're not already a member.
This is the schematics, I already have it and also the service manual. Looking for the user guide. It seem to be more rare!
Tuck
6
Many thanks Jimmy,
you give me the hope to fix it!
Does anybody know a place for repairs in Paris (France)?
5,747
262
We have a member in France. bredgeo
Nice guy!
PM him. He will be able to help you!
It is actually not that hard to work on 9696.
I got one and have worked on it to change belts and all.
You will have to put a sleeve on the capstan.
The rubber goes bad and become a sticky mess.
That capstan rubber sleeve is the main part for play function.
Beosystem10
1,807
UK. 55.7710° N
OK so, as luck would have it there's a copy of the owner's manual available from my dropbox shared folder, the one with the vulture or whatever it is on the front cover and the instructions about how to use the machine.
laurnalhac
Tuck said:
Many thanks Jimmy,
Tuck said:
Hi guys,
Hi guuy,
The push button mechanism on / off no longer works because of the dirt that comes down and halt the mechanism.
You must remove the housing and inject W40 on the white back of the button, the W40 cleans and lubricates the mechanism.
good luck
