Can somebody please explain the eject and return drive of the turntable please ?
I have a feeling it is meant to eject when you open the front panel, is that correct ?? but mine does not.
What mine does do is slightly retract when you push play for it to play a record and then
eject back out when you press stop.
I would believe this is correct and also shows that there is power and drive to the slide out
mechanism of the turntable, just no initial eject at the start
And when you are finished with the turntable how does it fully retract ?
At the moment i have to manually eject and retract the turntable but that cant be right ??
Also the cassette is not playing so any info as to the level of difficulty for replacing the
belt for that would be great too
Thanks again.
Thanks again.
