Jump to content
Kaboom Power Issue , solved ..
3 replies to this topic
#1 stynger007
stynger007
  • Members (SA)
  • 174 posts
  • LocationThe Great White North Canada
Posted 15 September 2013 - 04:32 PM
 Hi everyone , picked up an JVC RV-DP-100 Kaboom box on a local classiified site for $10 .. came with remote, strap , pouch for remote and power cord.
 Problem : Unit would sit in standby mode, when pressing the power button , it would power on for 3 seconds then shut itself off.
 After some research , even tried resoldering circuit board connections , freshening the joints. Didn`t work , same problem.
 Removed the top carriage that houses the cd player and 2 other boards , one , the middle one , contained the IC`s ..
 Attached File  IMG_20130915_153518.jpg   122.59K   42 downloads
 Removing all ribbon cables, found corrosion on several tabs ...Attached File  IMG_20130915_152941.jpg   55.4K   42 downloadsAttached File  IMG_20130915_153121.jpg   65.18K   43 downloads
 Proceeded to clean the tabs with a utility knife blade ...Attached File  IMG_20130915_153127.jpg   70.53K   40 downloadsAttached File  IMG_20130915_152952.jpg   76.84K   38 downloads
 Here is where the  cables were plugged in , cleaned these as well..
Attached File  IMG_20130915_153603.jpg   119.38K   37 downloadsAttached File  IMG_20130915_153606.jpg   126.05K   38 downloads
 Carefully reassembled the unit , and no power issues at all.
 The cd player works, the cassette needed a belt and a slight azimuth adjustment .. The new  owner of this $10 Kaboom, is very hap-pay! :-)
 Attached File  rv1.jpg   58.13K   41 downloads
 Just figured would put it out there in case someone else ran into these types of problems on their kabooms...
 Have a great night everyone! ;-)
#2 Jboogie2384
Jboogie2384
  • Members (SA)
  • 1,267 posts
  • LocationQueens, New York
Posted 10 December 2013 - 07:33 PM
I have the iPod version with a power issue. Might have to try this out. Won't turn on at all. I'll tear into it after the holidays. Thanks for the info.
#3 dragonballz
dragonballz
  • Members
  • 1 posts
Posted 28 April 2018 - 06:59 PM
Thanks for these pics.
I am the original owner of one of these. My problem was that it would not power on with either the AC cable or with D batteries. I took off the back cover and jiggled some stuff around. It powered on. More specifically, when I apply some firm pressure onto the DC connector, the speakers pop then it powers off. I will completely dissemble the boombox to get a better look at the board. I'll take a look at the ribbon cable pins too.
I have never used the DC connector as I do not have one.
PS: what the heck is with XXVII, ยง 3, Part 2, of subset "D"
#4 JVC Floyd
  • Boomus Fidelis
  • 6,552 posts
Posted 28 April 2018 - 07:12 PM
My guess would be either bad cold or broken shoulder joints where the socket goes in the board.
