How the heck do I get to the belts on a Sanyo M9977? I thought the Sanyo M9990 was difficult, this one is worse!
I know bill, for some reason I can't figure out how to remove the amp and tuner PCB to get access to the tape transport. I have removed every screw and yes eject the cassette door and still I can't remove the PCBs to get to it. Something is still holding the PCB. I have never seen anything like it.baddboybill said:Alberto I was speaking of getting to belts. Mechanical decks are usually fairly simple with just removing plate since there is no extra parts like auto deck I'd be interested to see pics of deck
Bad Boy Bill
if the tuner pcb won't move have you tried pulling off the tuner knob?Alberto said:I know bill, for some reason I can't figure out how to remove the amp and tuner PCB to get access to the tape transport. I have removed every screw and yes eject the cassette door and still I can't remove the PCBs to get to it. Something is still holding the PCB. I have never seen anything like it.
Yes all knobs are off. I'm just surprised that no one has commented on this post that actually worked or restored a Sanyo 9977.JVC Floyd said:if the tuner pcb won't move have you tried pulling off the tuner knob?
I can't see the deck mech yet. I have no problem desoldering or soldering wires. I don't know if I'm just having a brain fart or what, but i just thought if I post this as laughable as it may seem maybe someone might have had some experience with this boomer and chime in.baddboybill said:Have you tried taking whole deck mech off? I've had to do this with Lasonic TRC918 and my CEC. You may have to desolder some wires post pics
Bad Bad Bill
no chassi, nothing like the M70.baddboybill said:So is there a frame that can be fully taken out? If so that's where to start
Bad Boy Bill
In many cases there are several hidden screws. In some case it is a board connector, or an external connection in a slot. It is very frustrating when we cannot find it....docnak said:i will post pics of my current attempt of repair on this model, although there isnt much to see because i cant get anything off! They will be in a different thread tho.
