Aiwa cs880u
sweetboy220466
43
Harrow, London
Morning everyone, can anyone point me in the right direction of getting cassette belts for an Aiwa cs880u need them as soon as possible.
Also need to get hold of a refoaming kit for the woofers too. If you have any info can you give me the heads up please. Thanks.
6,324
455
Seems like every 880 I see needs to be refoamed :huh: .......I wonder how long the foam lasts......30 years? Doubtful......I'm betting the original owner had to replace them once or twice during the 90's or 00's
sweetboy220466
43
Harrow, London
Yeah, maybe
BoomBoomBlaster
208
Germany
if you don't blast it at maximum these foams last 30 years :yes: depending on the quality, biggest fail is if you just refoam the middle passive radiators when the outer speakers "seem to be good" because it's quite offierce that the speaker foams will vanish after you really use your aiwa again :breakdance:
ahardb0dy
Don't know if this company ships outside of the US but you can ask. ( checked their site it does say they do international shipping)
http://www.adamsradio.com/
I also found these 3 different belt numbers for the CS-880's, I replaced the belts on mine but don't know if I saved the part numbers that I used, will look tomorrow.
these are the 3 belts I found, original Aiwa part number and cross referenced PRB part number:
Aiwa part # - PRB part #
82-585-336-010 - SCX7.4
82-585-287-010 - FRY10.0
82-587-209-010 - SCY6.7
Ghettoboom767
4,307
56
Will these belts fit the Aiwa CS770U? I heard the 770 has the same deck. :hmmm:
Any help would be great-having to order belts for a few boomers
next week. :-)
