Very carefully. And take lots of pics of wiring. Bad thing with Conion is wires are pretty much same color and even same amount per plug. You can also put labels on wires where each goes. Only other difficult part is when putting frame back in the bottom tape deck is tight and you need to be cautious. . Good luck
