Just got a Walkman EX-618 NM off E-Bay. It came with the remote external battery attachment and headphones. It works well and sounds very good.
It is quite then and has AMS and can repeat a song over and over.
It plays but I can tell that the belts will most likely need to be replaced. With a 15+ yrs old unit, that is to be expected.
Does anyone where know where i can get the right belts for this model? Also does anyone here quite experienced in doing repair and belts on Walkman's/
Thank you for your help.
