Hitachi TRK-3D80au
The Box of Boom
333
47
Sydney/Australia/Earth
Hi Guys
Is there anyway I can access the back of the speaker grills on this radio so i can attempt to bend back out the speaker grilles ? Is this an easy radio to do an internal clean ?
Thanks :breakdance:
monchito
4,602
11
pythonville florida
hi u must remove the front case portion to get to the speakers :-) then u should see the metal tabs and there u should be able to pull the grill off ..btw can u post a pic of the box in question???? :-)
The Box of Boom
333
47
I can post a photo after christmas. It looks exatcly the same as the 3D80e I am pretty sure. I am a bit of a novice with opening up boxes - any links to tips on giving internal maintenance. i.e. where to spray deoxit etc.
3,600
14
51
Belmont, Australia
Using some thin wire or something else hook shaped you can usually thread it through the speaker grill holes then around and back out. You can then pull the wire gently to pop the grills back out. A goog idea is to thread string through the holes, this eliminates the risk of scratching the paintwork on the grills.
Good luck!
RockE
199
Australia
Good luck!
Glue is spot on, I've also used a small fish hook in the past with a pair of pliers to pull out dents in my 3D's
