I'm starting to notice that sealed blank tapes seem to be worth quite a bit of money for some reason, why is this? And what makes some more valueable than others?
1) Like Boomboxes, they don't make the good ones anymore. Tapes are still made, but only Type 1's, and I believe there is only one factory in Thailand (Imation). This factory produces Sony EF's and TDK D's although there has been talk recently that TDK D's are starting to disappear off the shelves. There are a few very low quality chinese brands still available, but they are not worth the plastic they are wrapped in.Mountainlife said:I'm starting to notice that sealed blank tapes seem to be worth quite a bit of money for some reason, why is this? And what makes some more valueable than others?
So true, Terry. Used metal bias tapes, unless they are just absolutely trashed, can be used many times over without noticeable loss in quality (with the proper setup). I have found a few at local thrift stores and snag them whenever I see them. I keep hoping I'll find a TDK MA-R in the pile one day.Terry said:...If you see any used metal tapes grab them,...
A few recent used finds,Fatdog said:I keep hoping I'll find a TDK MA-R in the pile one day.Terry said:...If you see any used metal tapes grab them,...
YES ! Totally . . . . .AND . . . . . the deal with Metal tapes is that you can record onto them at a higher recording volume without distortionStrÄnj-BÅÅmbÅks said:Hey Mountainlife brother!
Metal (Type IV) tapes are the ones that reproduce the nicest sound quality out of the rest... also, for the people who don't like to record on them, they're the most collectible (rare)... Take care bro!!!
I would say it's a little bit of both. A true tape aficionado will pay money for what he considers to be the best cassette tape. Remember, the really good stuff is not being made anymore.Mountainlife said:Just trying to figure out of people are buying and paying high prices for blank tapes to record on or because they are collectible
I'll second that, I try to keep the sealed tapes sealed because once you open them value and collectibility take a big hit.Fatdog said:I try to find open tapes (good CrO2 TDKs or anything Metal) to record on. Usually, I'll keep the sealed tapes sealed unless I have lots of duplicates.
WORD!! You don't know how many times I've put it on 'Metal' for metal bias tapes and have been disappointed, even when I recorded on my 3-head Sony cassette deck. The 'Metal' position has NEVER worked good for me!Reli said:Funny thing is, no matter what kind of tape I'm playing, I always leave the selector on Normal. The other settings cut the highs too much.
Hi Mono - Be careful doing this, as the full 110mins of tape probably won't fit properly. Reel tapes typically use larger hubs than the MA110. IMHO, you'll have less frustration (and potentially less waste) using tape out of a metal C-60 to make yourself a better-quality reel tape for demo purposes. And keep those 110's to make some long mixtapes with your favorite tracks for everyday listening.MONOLITHIC said:I bought a lot of 3 TDK MA110 Metal bias tapes on eBay for $25... http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0807713183 with plans of gutting 'em and throwing the actual tape in 3 of the normal bias reel cassettes I have (love the look, hate the sound), just mostly for display purposes for videos and whatnot.
